How hard is it to convert an auto over to a 5 speed? About to do to a swap to a h22 and would rather have a manual than auto. And it is it extremely costly?
Auto to 5 Speed conversion
91 LX Under Construction. http://www.cb7tuner.com/vbb/showthre...00#post2017900
Tags: None
yeah it's definitely gonna cost you a pretty penny. when i had my accord i was gonna do the same thing but decided otherwise. the only way to beat the price is to find a junk yard with parts from a wrecked 5-speed cb7 and get all the stuff you need. that's what's gonna cost you the most (other than the engine of course). and if you're doing the work yourself it's gonna be a little time consuming but you'll definitely save some money there. good luck man...be sure and let us know how it goes
Originally posted by Sway View PostHow hard is it to convert an auto over to a 5 speed? About to do to a swap to a h22 and would rather have a manual than auto. And it is it extremely costly?
As far as cost, you usually have people parting out their cars in the classifieds for pretty good prices.
I got everything need for a 5spd swap for $150 minus the tranny, clutch and flywheel.
So it all depends where you look.
I was thinking about doing this to my cb when I get a new f22a6. But it seems like a whole lot of trouble...
Slamage is worth the Damage
Originally posted by crazymikey"Yes, we did officer. By the way, your eyes look a little glazed, did you just come from the donut shop?"
On a scale from 1-10 I would rate it a 7. You have to do your research!!!! If you got ALL of your parts it will go like clockwork! The major hassle to me was the mounting situation. You have 3 options:
1. Either weld on a MANUAL BRACKET from a 5spd car because your automatic bracket WILL NOT line up with your trans mount.
2. You stated you are going to use an H22 engine and trans. If you was to grab a Prelude trans mount you can drill and tap the holes on your H22 trans to mate with the mount. Then your auto bracket will line up correctly with the prelude mount. I know its more to it than what I stated but I Think I did hit on the major concept.
3. Purchase the ESP mounts. These mounts are very strong and will just bolt right up with no alignment problems. No need to worry about motor mounts for a long time.
These 3 options I thinks are the only ones available for the mounting situatio n. Once again, I highly recommend you do a ton of reseach before you attempt to do this. I did. and with a lot of blood, sweat and tearsI got very impressive results!!!!
