I just finished my h22a1 swap and my intake vacum is only 10 inches now I checked my egr and adjusted timing and nothing still @ 10 inches, now I think (not sure) that the problem could be a vacum hose. The one @ the opposite end of the throttle body there's two hoses one for cruise control and I don't know where the other hose goes can someone help me out please
low vacum pressure
So I unhooked the vacum to the fuel pressure regulator and the vacum pressure went up to 14 now my question is could it be the oxygen sensor that I don't have cuz the wires got pulled out, can my air fuel ratio be messed up cuz of thatOriginally posted by bliz07 View PostWell I'm at school now and started the car and now the pressure rises from 2 to 10 and I have no clue what it isStuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
Thanx budOriginally posted by wed3k View Postid use brake clean or carb clean, spray around the manifold and if the idle rises then you just pin pointed your spot.Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
How does the car run when its idleing?
Sure your vac gauge is reading correctly?
My 5.7 LS1 Holden Ute
Originally posted by bliz07 View PostSo I unhooked the vacum to the fuel pressure regulator and the vacum pressure went up to 14 now my question is could it be the oxygen sensor that I don't have cuz the wires got pulled out, can my air fuel ratio be messed up cuz of that
Well since I disconected the egr and fuel pressure vacum its running at 14 inches with both connected it hit 2 iches and kept bouncin to ten, my teacher said it could be that I don't have the oxygen sensor connected and it could be leaning outOriginally posted by evil_demon_01 View PostHow does the car run when its idleing?
Sure your vac gauge is reading correctly?Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
Yea that's what imma do this weekend replace the o2 hook everything back up and if the problems not fix then I'm goin to check for vacum leaksOriginally posted by lost_accord View PostFix it first (replace broken O2 sensor), then trouble shoot. If you know there is something wrong take care of that first.Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
