Which proportioning valve to use?
    I bought a 93lx coupe 3 months ago and am getting it ready to put on the road.
    I did the vigor brake upgrade (92 vigor pads, rotors, calipers and carriers) and everything works.
    I know I need to change the prop valve but dont know if I need an adjustable one or if one will work from another vehicle. I really dont want to change out the rear drums for disks.
    Any advice?
    Thanx
    You don't need to change the prop valve for a front brake upgrade.
    1992 Accord Wagon (RETIRED)
      Im confident you do need to. The fronts lock up too easily.
      The rear brakes are in great shape, everything moves perfectly as I serviced them. They are adjusted.
      The car stopped normally before the upgrade.
        The proportioning valve's purpose is to reduce the amount of braking power sent to the rear brakes, as the front brakes do the majority of the work. You do not need to change your prop valve.
        What happened was, you upgraded to larger brakes, so the car stops more aggressively.
