Acceleration
    Acceleration
    My CB7 an acceleration problem when I floor it at rest it just bogs down and accelerates slowly. It almost stalled this morning. Its starting to be a safety risk... any ideas?
    -Will
    did u check your gas filter? or put gas treatment u might have bad gas in the tank. injectors might be slightly clogged...
    wen yous in da import seen yo, u gotta tipe lyke yous from da streetz cuz it showz dat u git mad rezpect yo. toonerz dun tipe lyke dey gotz a edjakashun cuz dat aint coo.
      Kinda a newbie at working on cars so no I havent checked anything... How exactly would I get to the fuel filter?
      -Will
        if your looking under the hood its to the left by the fusebox under the vacum lines its like a round black tube
          like he said if your looking at the engine its beside the fuse box but its mounted on the firewall
          My cb7
          h22a
          5-spd lsd
          Lord, grant me the serenity
          to accept the things I cannot change,
          the courage to change the things I can,
          and the wisdom to hide the bodies
          of those people I had to kill because they pissed me off.
            Alright il check that when I go home
            -Will
              sh!t well u have it out u mines well put a new one in anyway but if that dosnt work let your car run til the gas light comes on and go put 91 or 93 gas in it and see if that helps if not might be the injectors
                Well it started doing this long before I even got the car... Right after the timing belt popped.
                -Will
                  your timing might be off also but check the gas stuff first then if it dosnt fix the problem check the timing if its non of the above check your throttle body
                    mine did that all the time too.. changed the O2 sensor cuz my half shaft was rubbin on the wires and it eventually went threw.
                      did u ever find out the problem?
                        Or what about a tune up?
