my name is duane and i did an h22 swap and was having trouble with my tires spinning like crazy,so i did some research and im planning on getting some (nitto neogen zr) 215/45/7r 17 what do you guys think?
my tires
Look at your current tires and see where they're wearing. Unless you have absolute garbage tires, you shouldn't have traction issues unless they're worn out. You're quite low, so you may be getting some nasty camber or toe wear on the inside of your tires. They may look good on the outside, but essentially be bald on the inside. If that's the case, you'll want to fix that problem when you get new tires... or you'll destroy those as well.
