does anybody have the link to the DIY on replacing the valve cover gasket and tube seals? i searched and couldnt find it.
Valve Cover Gasket and Tube Seals Thread
Damn, I just did mine a couple of days ago. I didn't think to take pics.
It's honestly not that hard though; just unhook the PCV and breather hose, take off the spark plug boots(try to keep them in order), take of the 4 10mm valve cover bolts and one 10mm ground bolt; remove VC(may require some prying); make sure seal surfaces are clean and you can use a bit of oil, replace the seals(tip for the valve cover seal; press on it starting from the middle. do not slide your fingers across it); reinstall and be sure not to overtighten the valve cover bolts(I use a nut driver just in case instead of a ratchet).-Kevin
1988 Honda Civi- D15B VTEC Dac Biet, my "race car"
1992 Honda Accord LX: DD until I finish school
Originally posted by 1993 CB7 LX View Postalright, last question. i have oil all over all 4 tubes and inside spark plug chambers. is it necessary for me to pull the camshaft and replace the lower seals? could i get away with just replacing the valve cover gasket and upper seals? or do i have to replace the lower seals also?
Most of the time its the lower tube seals. Most people look at what they have to go through and say screw it ill just leave those alone. If you are going to do tube seals you need to do them right and do the lowers too. I also wanna ask if your car has a slight skip at lower rpms. My middle tubes are drenched and I think its causing a misfire.
Originally posted by Shag Wagon View PostMost of the time its the lower tube seals. Most people look at what they have to go through and say screw it ill just leave those alone. If you are going to do tube seals you need to do them right and do the lowers too. I also wanna ask if your car has a slight skip at lower rpms. My middle tubes are drenched and I think its causing a misfire.
Also, another question. i wanna do this right, but i have only a ft-lb torque wrench at school, u know, the ones you torque tires with usually. do i need an in-lb torque wrench for when a put the rocker arm assembly back in? or can i just tighten them without one?
That should b plenty if you know your way around the motor. Just dissassembling everything shouldn't take longer 10-15mins. What you can do is buy or check out a manual and study it for a bit so you know what to look for.-Kevin
