where are the timing marks on the crank pulley
timing marks on cb7
It's easy to adjust the timing using that flywheel mark and a timing light.
The mark is supposed to be offset by 15 degrees. If it's offset more than that, then your flywheel was installed incorrectly.
As for the original question, the timing marks on the stock crank pulley should be visible. They are not to set ignition timing, but to ensure that everything is set correctly... you need to match the TDC mark on the crank pulley with the TDC mark on the cam gear, or you're going to have incorrect valve timing... and most likely end up with a valve and a piston getting into a brawl in the first revolution of the engine. The piston will win... but it won't be pretty.
