can a f23 crank fit in a f22a?
f23 crank
Originally posted by deevergote. View PostWhy are people so stuck on the "g22" crap? The F22, especially with a turbo, can make more power than street tires can easily handle, and be far more reliable than anything slapped together from multiple motors.
to the OP, listen to deev. being different cost money. if you dont have the money to do the G22 thing then dont do it. you'll end up taking short cuts and blow the motor and would have wasted a load of money.
Originally posted by deevergote. View PostIf it's your daily driver, and you need it to get around, don't do anything to risk reliability... of course, going turbo kinda throws that out the window. Turbo can be fine, or it can be a major headache.
1-its fun
2-and its nice to hear that BOV
3-you learn a lot during the boosting process
it can be a headache for:
1-its addicting. you'll want to start pushing more boost which means more engine stress which means a permanent hole in thew block to see the inner workings of a combustion engine or a motor build.
2- if you dont get the right person to do the tuning, you could end up having a crappy tune which can also blow your motor.
3-getting cheap parts(turbos, intercoolers, etc,) could cost you more in the end.
thats your bf fault then, for not knowing that increasing stroke increases compression.
there are plenty of f23 crank/rod combo H's that are running high comp n/a, thats decently torquey as well. i dunno if i would trust the f23 crank/rod combo for boost though. just that stroke would kill it.
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
yeah i know its not going to be reliable and im going to take my time for that build and get it done right. the reason i want to build a g22 is because i always want a h22 but almost everyone had a h22 in a accord so i wanted something different and was told to boost my f. but i still wanted vtec so this will solve all my problems with a g22 turbo. i should have a street bike by that time hopefully but im going to be boosting the f now and have a extra block and maybe a a6 motor on the side so i should be good. thanks for the replys and advise.
Originally posted by bagoon316 View Postthats your bf fault then, for not knowing that increasing stroke increases compression.
there are plenty of f23 crank/rod combo H's that are running high comp n/a, thats decently torquey as well. i dunno if i would trust the f23 crank/rod combo for boost though. just that stroke would kill it.USDM [H] PiMP
iP0P VTEC
WhiTE B0Y!!!
I read in IMPORT TUNER that combining the f23 block with high compression k20 pistons and an h22 head made 237 whp! i also read it had cams and hondata i think, and also that it was cheaper than buying a k20 motor. I don't know how reliable is it but I say go for it, the g22 and g23 is our version of the ls/vtec or b20/vtec.
