Getting CEL 5 MAP sensor?!?!?
    umm...why? what is it?
    Check the connections, it may be bad. The MAP is located inside the black emissions box, which is to the right of the engine bay fuse box, mounted on the firewall. On the outside, it's the 3 wire connector, not the 4.
      if you have to replace it just go to the junkyard and pocket a few of em.
      they are effin expensive if you buy a new one.
