Hesitation Upon Acceleration
    Alright so once again I'm still having the same hesitation problems with my 92 accord. The car accelerates fine when it is cold, but once it warms up and you accelerate the car hesitates bad then rev's fine. Also when driving at lower rpm's the car jerks alot. I have replaced the plugs, wires, cap and rotor. Also when I have the coolant temp sensor unplugged the car experiences no hesitation but idles much higher. I have no idea where to go from here and would much appreciate some direction.
    thanks.
    have you pulled any codes?
    http://www.cb7tuner.com/vbb/showthread.php?t=167601 Click to see my new ride
      Egr
      I would bet on egr, look up diy on how to clean it, you may have to remove the intake manifold and drill, clean, tap the egr service ports.
      Good luck, hope you get it figured out.
      201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
        Nope, will there be any even though check engine light isn't on?
        I've looked into this and believe this is not the problem but I am planning on cleaning them anyway within the next week, I just need to get my hands on a slide hammer.
