Anyone have any ideas how i can stop the flywheel and the pressure plate from spinning? i'm trying to get those 12 point bolts off to remove the pressure plate but the thing keeps spinning at the PnP. Some dingdong cut the belts otherwise i'm sure that would help a little, i've even tried shoving my prybar in between the plates and the engine but it'll just spin free from the force i'm using to break free the bolts.
Pressure plate removal
The motor turns over w/ you trying to remove those 10mm 12's? Hmmm, are the spark plugs removed? I forget the torque spec, but those shouldn't be a big deal, the f/w bolts are a much bigger deal! Well, how about a 19mm deep socket on the crank pulley bolt w/ the ratchet or breaker bar in the opposing direction (to the front)? Or a prybar catching a tooth of the f/w through the cutout in the block for the inspection plug?
