I want to modify the oem muffler...basically im thinking of using 2.5 inch mandrell bent exhaust piping under the car with the casing of the oem muffler and modified oem exhaust tips. Anyone know about opening up the muffler and installing something more efficient? Any ideas or suggestions?
Muffler Modification
Originally posted by abs-lsd View PostNot a fan of those...its gota look stock, im building a low key car...
Edit:
Or weld in a straight pipe connecting the inlet and outlet and pack the muffler with fiberglass, essentially making it into a stock looking glasspack.Last edited by JoshM; 03-24-2009, 12:34 PM.
Originally posted by Joshs92ex View PostCut open the stock muffler, cut everything out, weld muffler back together. (If you don't mind noise.)
Edit:
Another option is to find a factory muffler from another car with a larger outlet. It won't be CB7-stock, but it'll still be an OEM muffler, not an aftermarket coffee can. The RSX-S muffler has been a popular choice in the past. Maybe something from a turbo car would have a 2.5" inlet and outlet...
You should look into getting a long resonator or two, whatever you can fit, to reduce the noise. Looking low-key won't help if you're loud!
Finally, my last thought would be to run the stock muffler with an electronic exhaust cutout. When you want speed, you open the cutout and run a muffler-less 2.5" pipe. When it's closed, you might as well be stock.
