whats wrong with my transmission?!?
    when im doing about 75 my rpms are at about 3.5k is this normal??
    yessir sorry forgot to put that
      torque converter not locking?
      i drove an automativ and the revs were 3k at 60mph. it was kinda wierd but then again it is only a 4 speed.
        idk...also when im driving and the car shifts from lets say 2nd to 3rd it revs up really high then goes into gear....but im thinking that problem is the cable thats leads from the throttle body to the tranny cuz just recently the bracket that holds the cable came off idk where but it did the screw's missing n everything lol
          check your fluid. that cable is the kick down cable so when you floor it it will kick the trans down a gear. that sounds like slipping to me witch i had the same problem in my 92 4door you might need a torque converter or a new trans, you might just be low on fluid.
          Hey yo uhhhhhh fry man!!!!
            The delay shifting could be tranny solenoids and the high rpm while doin75 mph could be your torque converter not going to lock up
            Stuff 4 sale 2nd gen dsm turbo manifold, ebay type s blowoff valve, 93 ex pt6 ecu, f22a6 camshaft, f22a6 intake manifold, obd1 p13 ecu
              Thats not that high for an automatic 4 speed tranny... i have a honda certified rebuilt trans in mine with about 2000 miles on it now. and at 70 i'm doing 3k. but from everything else you said it sounds liek your trans is slipping. Check your fluid level, but usually once its slipping then the damage has already been done. Also you can add some Lucas trans additive and see if that helps it some.
                damn i could have sworn i just said the same thing. huh?
                  offended?
                    Time for a 5-speed swap. 80 MPH = 3k for me.
                      Sound like normal to me.
                      My buddy's has the same thing with both his cb. Even its the same to my auto cb.
                      Just check your tranny fluid.
                        i checked my fluid its fine...maybe it is the converter.i hope not! =(...i wanna do the A2M swap but idk how hard it is lol
                          On my auto tranny I don't hit 3k till 80.
