changing headlight bulbs.
    OK first and formost. I DID Search for 20 mins and didn't find anything.
    I need to change the bulbs in my headlights.
    I don't have the factory manual so I couldn't look it up.
    I thought they just rotated to one side and sliped out, but my fat hands don't fit between the battery so well, so i used some plyers and snaped off some plastic.
    So how do they come out?
    Should remove battery than
    Or used flat like I did slowly it will turn once it turn you just slide it out.
      well, now half the bulb is still in the headlamp. and the driver side light is just as hard to get at, and I cant remove anything on that side. I see what appears to say "lock" and an arrow so I should be turning the other way.
        Well i got them swaped.
        The issue was that I didn't know that the plate that holds the bulbs is what rotates, NOT THE BULB, don't turn the bulb or they will crack off. It was effortless to rotate the retaining plate. I had to remove the battery to get to the broken bulb.
          so is everything good now?
            The best part of this is its a learning experience! Glad to hear you got them changed. Just dont snap off your bulb next time lol!
              Rotating the plate can be difficult if it hasn't been done in a while. A flathead screwdriver helps.
