i searched everywhere and cant find how to remove cruise control. can anyne help me?
cruise control delete
Originally posted by DImages56 View Postim not sure if its the same as a civic (manual). but you disconnect the vacuum hose to intake manifold and the cable that goes to the clutch pedal. you will need a cap to replace the vacuum hose on the intake manifold or else you get a really wierd idle.
hope this helps
1. Unbolt the Cc
2. Remove Cable
3. Trace vacuum to IM
4. Disconnect vacuum line, and put a cap on the nipple
5. Follow other Vacuum line to Drivers side fender well
6. Disconnect the Line, and or remove fender liner and take out the little black box.
I wouldnt really worry too much about the relay.
-Jordan
I ♥/Miss My Coupe
Originally posted by civic_90_08 View PostAlmost there.
1. Unbolt the Cc
2. Remove Cable
-Jordan
Originally posted by the pharmacist View PostJust to be a little more complete and specific, in order to completely remove the cable, you'll have to first remove the plastic grommet on the firewall. Then take a look behind the gas pedal and you'll notice that the cable is notched in a certain way. Maneuver your way around this and you'll have cable removed
I ♥/Miss My Coupe
little black box
"accidents in the back seats cause kids"
but who says that i
have back seats in my sedan
THE ALASKA EXPERIMENT
where is it located?
but who says that i
