So i just did the timing belt again, oil got all over it, so it needed to be done. Got the new belt, slapped it on, and when you touch the throttle, it just wants to keel over and die, could the cam be off by one tooth?
Re-did timing belt, some seals - wants to stall at throttle touch
Originally posted by wed3k View Postyou mean you didnt check the cam and crank synchronization when you did the timing belt?
it shouldnt be a question, thats how valves get bent.
Any advice?
Nevermind, finally got it on the 8th try.Last edited by js593; 03-22-2009, 09:47 PM.90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Ends up it looks like something else. I put everything back on, and it still wants to stall out when you just tap the gas. all the marks line up, so im not sure what to think at the moment. I'll take a 2nd look at it tomorrow, adn even have work look at it.90 Accord EX F22a1 Auto R.I.P.
Originally posted by wed3k View Postmessed with tps yet? condition of spark plugs?
this happened to me after an automatic transmission R&R and the car would choke upon start up and die wheveer i got on the gas. turns out the plugs havent been serviced in a million years.
While i was doing all this work on the accord, i also cleaned up my tentioners. They were caked with oil and crud inside, so they werent springing up like they were supposed to.
Ive attached 4 pics of where the cam WAS, and i will upload a few more once they upload to my photo bucket. (on a USB 1.0 system right now lol....)
Thanks Wed for the help so far.
Originally posted by wed3k View Postbecause you know you are supposed to dial your TPS in whenever you change it?
if you have a vacuum guage, plug it into one of the free nipples on the back of the intake manifold, starrt car and monitor the guage. it should be steady and in between 17-21 in-hg.90 Accord EX F22a1 Auto R.I.P.
Originally posted by js593 View PostUnfortunatly i dont have a vacume gauge Any way i can go by resistance with a meter?
for the TPS, you are supposed to tap into one of the three wires for the tps, leave ignition to II and test voltage at closed throttle and WOT.
i believe there's a DIY on it.
Originally posted by wed3k View Postwell, the vacuum gauge thing and tps were two seperate things. you can see how well the engine is running via vacuum.
When i got my vacume tested before, he said it was at 20. Which was perfect. This however was a while ago.
Here are the pics i have with the cam ajusted.
Lemme know if thats in the right place. since i have that plate in the back, its kinda hard to see if its dead on.90 Accord EX F22a1 Auto R.I.P.
Originally posted by wed3k View Postthe pictures are really blurry. back up a tiny biit.90 Accord EX F22a1 Auto R.I.P.
Originally posted by jaykilla116 View Postdid you make sure there is enough coolant?
The coolant was the first thing i checked. right after i did my timing belt.
Even though its a *possibility* it would have to be dreadfully low, so low that the engine would probably overheat before throwing a code.
Considering the fact that i also check my fluids EVERY morning before starting my car, i knew for a fact it wasnt the coolant. And since it started happening right after i finished the timing belt again, that kinda gave it away.90 Accord EX F22a1 Auto R.I.P.
