Header qualifies for replacement?
    Well, I took off my heat shield for the first time on this car and this is what caught my eye first - a crack on the header.
    You can see it lower left on this image
    So... does it qualify the header for replacement? What are the dangers/discomforts of running a cracked header?
    HONDAMENTALISM
    hmm..... F22A2
    Well, if you have a cracked manifold then i would suggest replacing it with another OEM manifold or an A4 header. that would be the cheapest route and the A4 gives you just as much hp as most aftermarket headers. Minus the high end $500+ ones.
    Plus you won't have to worry about it anymore.
      Originally posted by Flatline View Post
      hmm..... F22A2
      He's in Poland.
        Originally posted by Joshs92ex View Post
        He's in Poland.
        i realized that after i pulled a double take. So will an A4 header be running around there?
          does it whistle at high rpms lol.? my f22a1 did on my sedan lol i bought a ebay one for 70 usd
          back at it again
            Yeah... A2... the weird spec Accord as it should be known as :P
            So I gather this one is done for then...
            Anyhow, as this car (and this particular one above all) is very rare in the EU, parts aren't as easy to come by as in the US, so my only choice is a direct OEM replacement, an A4 as you suggest (with all the madness that will go into convincing any Honda garage to sell me the part because they will follow my VIN no. and will go "But sir, this is not for your car!"), or a DC sports header (because it is the only aftermarket part available here...)
            At least I got my rusted old heat shield painted
            HONDAMENTALISM
              Weld it? That would be the CHEAPEST route. Although im not sure how well it will hold up. Is that a cast A6 manifold? If so, you can use the A2, A4, or A6, and just get new gaskets. Other route would be buying an aftermarket set.
              90 Accord EX F22a1 Auto R.I.P.
              2011 Mazda 3 Hatch 2.5L GS sport HELLO!
                Welding sounds like a nice cheap option but indeed how long will it hold. I'd just move square one ahead in time...
                I'll call Honda tomorrow and see how the prices go. I need a tune up anyway.
                HONDAMENTALISM
                  Welding cast iron seems too much effort.
                  http://www.lincolnelectric.ca/knowle...ronpreheat.asp
                  Hope you can get a replacement part. Almost everyone here probably has a spare, but shipping fees would probably be ridiculous, coz it's heavy as hell.
                  I love your car, btw! I wonder why...
                    [QUOTE=GearBangnAccord;1971022][url]
                    No selling in the beginners section!
                    1996 Honda Civic LX 2009-2012
                    2012 Kia Optima LX 2012-2013
                      Thanks lonski! I also wonder why
                      Shipping I can live with (barely) but not the customs and more tax...
                      Actually, come to think of it I wanted to change the header for a long time, but nothing justified getting an expensive header just for a few ponies.
                      Now though... hey, I'm beginning to look forward to a deeper growl of my little CB7 money pit
                      HONDAMENTALISM
                        have a A4 shipped out to poland. im sure you can find someone that will sell it cheap enough that if you fork the money for shipping, it would be worth it.
                          I called Honda today and they're gonna see how bad it is...
                          BTW... could a cracked header cause high fuel consumption?
                          HONDAMENTALISM
                            Possibly, yes.
                            If some how air was getting into the crack instead of getting pushed out, it would cause your o2 sensor to read lean, which would in turn cause the car to attempt to add more fuel. If you pull your plugs and they are black, I would say this is a definite possibility.
                              Ah! Well, the joke is that this model is not equipped with an O2 sensor...
                              Instead there is an IMA - Idle Mixture Adjuster...
                              see my post where I learned this the long way :P
                              http://www.cb7tuner.com/vbb/showthre...t=curious+case
                              HONDAMENTALISM
