Why? I'm confused I clean all the sensors that I could w/ carb cleaner. Then I used some seafoam in the intake manifold through vaccum line some in the gas tank and in through the egr hole. It was running good except a little high idle (@1100) for about 3 -4 days. Now it shut off after a while no stumble or weirdness, just shut off. Like if I turned the key. what could it be?
It just shuts off after 5-10 minutes
Will the accord ignition work on the h22? I did some searching and the control module is $65 then I ask the local jk for the whole ignition (for $100) from a prelude and they don't have none but they got plenty of accords. Could I swap ignitions?
who's real ? who's fake ? that's the people I hate
I had a problem like that also, just go 2 a junkyard and get all the parts. the distributor wont be hard at all to fix =) just take it off mark all the spark plug cables and on the disturbutor mark the holes. its simple and easy. GOOD LUCK AND MAY THE HONDA LAST YOU FOR AWHILE WITH NO TROUBLES NO BULLSHITS =P ...nah but good luck =P
