Plug wire replacement help - Magnecor?
    Hi!
    I just checked my stock OEM wires and they produce a 12.4 kOhm resistance...
    Does this mean I should replace them? I know that stock wires should be between 8-12 kOhms, but I read on TOV that anything below 25 kOhms is good.
    I know a lot of you say that NGK wires are best, but I also read that the Magnecor 8.5mm gives a resistance of 3 - 5 kOhms...
    What do you think... replace with Magnecor?
    HONDAMENTALISM
    I have two friends that got mag wires, they pop off the dist cap. Ill stick with ngk wires
    1990 accord Honda-Challenge, H22 powered
    newer race video,older race videos
    1991 accord parked, parts and back up shell
    1993 accord acquired 6-11-16
      blue NGK wires all day long
      90 accord EX automatic F22A4 232,500
      DIY ram intake
      0gauge/4gauge BIG 3
      stock alt rewound to 120amps
      optima orange top 830cca 1030ca
      fully synthetic valvoline "Max Life" 5w30
      Other rides:
      2004 Jeep Liberty v6
      2001 Honda civic ex coupe 1.7 vtec
        ngk, its from the facotry, it works.
        1990 accord ex - daily beater
        2006 accord se- family car
        mike aka caveman aka coupe aka cd8
          So not even the lower resistance as tested by Temple Of Vtec justifies anything else than NGK?
          I am really curious because I just literally now got into the topic of wires etc and want to know and learn...
          Facts, figures and your experience mostly would be sweet.
          HONDAMENTALISM
            unless your pushing 300+ hp, the oem wires are fine.
              NGK & Sumitomo (Honda Factory) hands down.
              1996 Honda Civic LX 2009-2012
              2012 Kia Optima LX 2012-2013
                well i am not shure if its any good but i run magstar wires from the zone and the are 8.5mm and i think they work
                  So now I'm torn
                  I can clearly see that NGK, Sumimoto are the most recommended, but I also thought that if you can replace a part with one that's better performing (which supposedly magnecor should be looking at the numbers), then that is the way to go even if not pushing more hp.
                  HONDAMENTALISM
                    true, but for me personally i cant justify spending extra money to see no noticable gains.
                    kind of like if it aint broke dont fix it
                      fuck, i got 300ohms of resistance from my msd's. i couldnt believe it.
                        i have had magnecores and ngks.....i really liked the magnecores but ngks are not to far behind. for the cost benefit ratio i would get ngks.
                          I got NGKs in the end.
                          Still those Magnecors look sweet with 3-5kOhm resistance...
                          HONDAMENTALISM
