Just got my oil changed and...
    So basically a couple weeks ago I noticed my car was shaking/ I could feel something wasn't right with the front end, especially past 40 miles per hour. I figured to let it be because it would probably be expensive for under body work.
    So today I got my oil changed and the shop told me that I need Sway bar links on both sides. I guess they are totally shot and almost gone. This fix will be under a hundred dollars so I'm content with getting it done. However, will this fix the issues I was experiencing?
    Thanks,
    JTM
    it's safe to assume that if you need it, getting it sone will make something better.
    I say do it for less that $100 and see whats up.
    You couls just need a tire balancing.
      i got the whole front end from ebay for 130shipped and put over 2000miles on it now with out any issues
        energy suspension polyurethane endlinks are only 15.99 at Autozone. Thats all you need to fix it with....can be done w/ simple hand tools and a jack.
          Sure, your front sway bar end-link bushings could be shot. Fixing this would tighten up your steering response/cornering. However, this fix would not take care of the problem you described (40 mph shimmy).
          The shimmy issue is more than likely a wheel imbalance, alignment, CV shaft or wheel bearing issue. You have to narrow it down. Also, an alignment issue could be the result of worn ball-joints throwing it off.
