Junkyard Oil Pan
    Junkyard Oil Pan
    Any reason not to get an oil pan from the junkyard?
    i wouldnt see why not, if you clean it out
    UNDERGROUND SOCIETY
    NEW COUPE MEMBERS RIDE THREAD COMMING SOON
      as long as the threads on the drain bolt aren't stripped and there's no damage. later.
      Avoiding dirt at all costs
        like no rust, dents, cracks..
          idk man, the last time i pulled an oil pan for a buddy at the salvage yards or the Pick and Pull, they punched a hole into it to drain the oil and then they plugged it with a rubber cork.
          if it's just a slight dent, you can hammer it back out with a block of wood and a hammer just be sure to clean it really good.
            That should be fine man, as long as your inspect if very closely.Also give it a very good cleaning after you get it,maybe a coat of paint on the outside.
            Check the drain bolt thread and threads on pan,visually inspect all dents and dings to make sure no one has welded on it, also make sure the mating surface is straight and even all around where it meets the bottom of the block.
              lol im most worried about getting under a car at the pick n pull... balanced on old rusty wheels
                Sure, why not just get brand new gasket for it.
                  i got mine from PNP
                  it works fine. go for it. just check it out before hand. be smart about it
                    i work at a PnP, and punch every oil pan, except a cb oil pan
                    no matter how rusted or fucked it could be i could not bare to punch a hole in it
                    Just do what PR CB7 said.
                      Whats the purpose
                        it's just the fastest way to empty the engine. gank a hole in the pan. pretty lame if you need a new one. lol @ PR_CB7 - thanks for helping save some parts!
                        Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
