Okay so i got my car inspected about two days ago, just to get a mechanics point of view of the car. My results were I had a bad o-ring around my oil cooler which was the cause of my burning oil smell, power steering minor leak, muffler rusted, and 120k tune-up coming soon(118,xxx miles) and my passenger side break was frozen as if it was being applied all the time (fixed). We'll to find out if wasn't my o-ring it was my oil pressure switch that was causing the leak so i got that repaired. But now my problem which wasn't happening like this before the inspection is that I'm now experiencing really bumpy rides just getting onto the highway is like riding a dirt road. Any idea? Ive searched the suspension part of the forum and Ive came across an answer that said it could be my struts, even though they were fine before the inspection and all.
Suspension
Do the bounce test.
Push down each section of where the struts are , if they have more than 2 bounces , they're done for.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
these model accord struts lock up when they get old and are put in the air on a lift for a moderate time. try the bounce test by pressing firmly down on each corner of the car. yes they will be bouncy if they are worn out or leaking fluid, but most likely one or more of them locked up while being in the air. push on each corner and if it feels like they are excessively stiff, your strut is locked up, replace
USDM as F$CK
Originally posted by Fake Thug View PostYeah I'd start with the bounce test too. .and krist will you^ stop changing your name?maybe you should change it to morph or mystique.. lol....
I've never heard that about our shocks, but it's possible, I suppose.
The shocks could still be weak, even if they pass the bounce test. They could very well be original. Mine were.
Also, check out all your ball joints, make sure your wheels are properly aligned, and see if your tires are filled correctly.
