I'm having a sputter at startup. It happens on random occassion and I'm starting to get irritated. When I start the car , I always let the fuel pump prime and start it up once the relay clicks. Once that's done I start the car up and sometimes it's sputtering mildly and catches itself after 3 seconds. Let the car warm up and it acts like it's normal. Drive the car around town, go home and rest if for a couple of hours. I start it again and the sputter is not there.
It first happened about 1 week ago, the second is today. I checked my spark plugs wires , spark plug , distributor internals , oil , coolant , main relay , ignition coil , oxygen sensor and they all look fine and dandy. All parts mentioned are approx 4 - 6 months old except for the distributor which is 1.5 year old and main relay being the original since mile zero.
Facts:
- Idle is set properly
- IACV is clean
- FITV is tight
- No vaccum leaks
- No exhaust smoke and no sweet smell
- No oil in coolant
- No coolant in oil
I'm suspecting:
- Fuel Pressure Regulator
- Ignition Switch
- Fuel Pump
- HG (my coolant in overflow bottle disappears)
- Ignition Timing
- Battery cables
- Weak ground
Any ideas?
Thanks.
Facts:
- IACV is clean
- FITV is tight
- No vaccum leaks
- No oil in coolant
- No coolant in oil
I'm suspecting:
- Ignition Switch
- Fuel Pump
- Ignition Timing
- Battery cables
- Weak ground
Any ideas?
Thanks.
