Blown Cylinder or Bad Sparkplug Wires
    So I used to have (Still do) a '93' Accord LX automatic. I was told that the cylinder #3 was blown and had no pressure. Well I just changed the distributor, rotor, and wires.
    I picked up a '92' Accord LX Manual. This weekend I switched the wires, distributor, and rotor. Well the 92 exhibited the same behavior as the 93. So I switched the wires back and worked fine again.
    I'm thinking my 93 is fine I just got some bad wires for it. So I'm gonna put the wires in the 92 on the 93 this weekend coming up and see how that works out. I'm thinking my cylinder isn't blown and it was just misfiring. See that the bad part a being a newb. You don't have enough experience to tell a misfire from anything else.
    What do you all think.
    IridiumCore
    HCK-The Beginning
    Your drunk she doesn't look that good.
    Sounds like you have a plan to trouble shoot, do that then tell us what happens.
    Click for my ride thread.
      Buy a compression tester w/ leakdown. If the pressure isn't even or close across all four cylinders you know you have a problem at which point you can perform a leakdown to help isolate the problem.
        If you think the problem could be a spark plug wire, why don't you just pull each plug one by one and see if they are all getting spark?
        PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
        Listen or download the first 4 songs I completed for my new upcoming album here!!
        My member's ride
          You know you guys all have great ideas. I gonna start with the cheapest route and just switch wires. I'll let you all know how that works out this weekend.
          IridiumCore
          HCK-The Beginning
            Check for spark,fuel and compression.
            www.PreludePower.com
            BB SQUAD MEMBER #28 V.2
              A compression test will tell you if you have a blown cylinder.
              I have damaged sparkplug threads on my third cylinder, and sometimes the pressure will push the plug up. When that happens, you can feel it in the plug wire, and it makes a knocking noise, as if the engine were about to blow up. I carefully put the plug back in place, and it's fine.
                Low compression doesn't nessisarily mean you have to tear down the motor all the time. Might just be a worn ring. As long as it starts it'll be "fine."
                Ghetto engineering 101.
                When the piston and ring warms up after being run a few cycles it will create a seal when the metal expands.
                Good luck with your car man, all I know is that even at high milage, these motors can take a beating with the correct amount of oil in them and being adaquatly cooled.
                  You ain't never lied.
                  IridiumCore
                  HCK-The Beginning
                    My Idea Didn't Work
                    Yep,
                    So it didn't work. STS was right its bad pressure. So time for plan two. I think what I'll do is get the H22 for my 5spd put the old f22 in the automatic and use that one while work on the 5spd(92).
                    Thanks again fella's. BTW does anyone know any cheap places in PA that will do the swap. My neighbors actually complained to the police and zoning board about me working on the cars. Damn nosey neighbors. Who knows I could have saved them some money. It's not like stains were left in the lot.
                    IridiumCore
                    HCK-The Beginning
