hi guys i searched for an answer but no luck my heater will only blow hot air it doesnt matter if its on cold or ac on vent or not its always hot checked the cable its fine and the knob is fine its a 91 se with the a6
heater only blows hot
The heater switch cable broke, This happened to me and it was stuck in heater mode, so I got a new cable from the dealer for 13 bucks, it was a pian in the ass to do the job because you have to take the center councel apart and then replace the cable, this happends due to age. Make sure when you replace the cable to use white lithium grease on all of the moving parts to prevent it from happening again.
Good luck
