I was wondering if a 91 acura integra radiator would fit in my 93 accord it looks the same but i was wondering if anyone here knoew for sure if it would fit.
will an integra radiator fit in a accord
you might have to move the rad mounting points at the bottom. also you can get a universal rubber hose that is bendable. you will probably have to make metal rad brackets w/ rubber bushings for the top or relocate the stock ones. i see people do this when putting 5th gen and civic rads in their cars.
any reason you want that rad over one that goes in there?later.
For memory The Accord radiator has 38mm in/outlets and the Integra has 32mm, So you would need to make an adaptor.
The bottom mounts will need to be relocated as TypeG said. They are only spot welded in, so you can easily drill them out and re-weld them to the new position.
Also you would probabally need to use the Integra fans to bolt to the radiator.
My 5.7 LS1 Holden Ute
