why not 10:1 for turbo?
    So a lot of folks like to turbo the f22 as it has lower compression and I HEAR that is a good a thing.
    While I grasp the concept of why...why not turbo a 10:1? It has more power as is, it would take less boost to make the same power as a lower compression vehicle and you would have more power out of boost correct?
    I eventually would think I would like to build my f22 for turbo, but for now I will keep it na.
    I apologize for being so broad with my question, but if I built my engine for n/a but with forged internals and to 9:1 or 10:1 some odd compression...what are the added risks of FI this engine vs keeping the compression ratio as a stock f22 has?
    And why would FI'ing this forged internals 9 or 10:1 f22 be a bad idea in comparison to the OEM compression ratio?
    ____
    it's very possible to do. the only thing is, with a cr that high, you would have to have a phenominal tune, and make sure everything was on point so as not to blow the engine
      ah...makes the tuning more finicky. Thanks for the info. I'm wanting (WAY in the future) to build my f22 with decent n/a power...maybe close to 200hp...I've seen several members here give some higher powered stock cars a good run for their money with only around 200hp n/a. I kinda want basically no boost under 3000rpms since I do my dd in that range, then boosting over that...so I would like decent power below 3000k...i still have to learn more before I really set my mind on things like that though.
      I figure higher compression (along with porting/polishing etc) would be the best way to go...maybe 9:1 instead of 10:1...I kinda want to build an n/a motor first, learn from it, then boost that engine as my second build (phase II sorta)...I just like to do things once, so i kinda want to put all the parts in the first go around that I would use for boosting...if possible.
      I have PLENTY of time to do before I even think of rebuilding an engine, to see what I'll need to mix and match for my preference on the build.
      ____
