Originally posted by DrSzSoLDIeR
View Post
Is this a fuel pump? (Pic Inside)
Originally posted by Konigstiger View PostPre-ignition , when all lights on the dash comes on (CEL , OIL , SEATBELT etc).
Originally posted by DrSzSoLDIeR View Posti believe i might have heard a click yea...should i check my relays first before anything? I cant remember right off the top of my head but im pretty sure i did hear a click
If the relay clicks then proceed on replacing the pump itself.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
It doesn't take long to fix the relay, plus its a good idea to do it anyway to rule it out.
http://www.cb7tuner.com/vbb/showthre...ght=Main+relay
You could also check for a power feed at the fuel pump when you turn the car on (when its priming)
My 5.7 LS1 Holden Ute
Not bad at all....
That's not a bad deal at all....
Honda's labour rate is about $90/hr.. and if they are having to drop the tank to get to it...that's a good deal...seeing as it would take them at least an hour or 2 to re and re.
What year is your car? Don't you have the access panel in the trunk?..otherwise you could do it in 15-20 mins youself, right?
..OH...and to make sure when they replace the "faulty" fuel pump... make sure they try the new pump connected while the tank is still dropped...if it doesn't try to prime then it isnt the fuel pump and you can keep the original one in and you don't need to buy or replace the fuel pump.
It sounds like just replacing the pump assembly will get you going.
:-)Last edited by Taurians' Ryde; 03-08-2009, 01:56 PM.
