squealing when i start my cb
    when i start my car i get a loud squeal from the engine compartment. i have tried to find out where it's coming drom by having someone start it for me. but i can't find it i'm quite sure it's one of my pulleys but don't know which one. has anyone had this problem before if so let me know. i hate that noise
    MOVING TO BACK FLORIDA IN 2 WEEKS. CAN'T WAIT TO GET BACK OVER THERE.
    happened to me too, change the belts
    can't please everybody.
    I don't want to hear it. I want fogs!
    MRT
    http://www.cb7tuner.com/vbb/showthread.php?t=129461
      what belts are good i don't want to buy any cheap shit
        well i went in to the pep boys and asked for the belts, and they just run through the ones they have quality and price, i got the in between one and that was last year and mines are still good so id do that
        MRT
          u cant temorarily stop it with soap and water. just pour a lil on the belts while its running and no sqeek. It only lasts like a day tho lol
            well when i did that, that actually made it worse, but the belts arent that expensive, just replace them
            MRT
              they might just need to be tightend up, (maybe there to tight also)
              when ever i did my alt they squeaked so loud
              then i tightend them and it went right away,
              if its a pulley, u might need to replace that part,
                cold weather does it to me
                  adjust them. too tight or too loose will cause it. Moisture will do so also if their not tight enough.
                    It's probably the alternator belt. When you first start the car the alternator is under load trying to recharge the battery. It's a combination of the battery sitting overnight and the use of the starter motor.
                    Be sure to consult the manual for changing the drive belts. Noooooo they are not adjusted by prying with a crowbar. This aint a damned stovebolt chevy.
                      thanks for the info i'll check those things today and try to get rid of it.
