Valve to loud
    Valve to loud
    Ok I am going to try this again because now i am awake. Ok so i just install a rebuild f22a1 engine and put about 6000 miles on it. It run great but the valves are loud as shit so i did a valve adjustment. They sound the same. What could this be?And also sorry deevergote to upset you.
    recheck your valve lash. maybe go just a bit tighter.
    member ride thread
    DIVULGE MOTORSPORTS
      I have check them like three times with in the last 2weeks. Thank for the help.
        What kind of oil are you using?
        90 Accord EX F22a1 Auto R.I.P.
        2011 Mazda 3 Hatch 2.5L GS sport HELLO!
          10w30 pennzoil
            What are you setting them to? It should be .010 Intake and .012 exhaust.
              i always set mine to .009 and .011
                get a good shop to do your valve adjustment, I did, and my engine sounds and performs like new.
                DEVOTE
                FS: Lokuputha's Stuff
                  ive found on most rebuilt motors that .009 and .011 is best.
                  member ride thread
                  DIVULGE MOTORSPORTS
                    I agree .009" and .011". Are you using the "go, no go" adjusting method ?
                    That means that for intake valves a .009" feeler gauge will slide in but a .010" gauge will not. Whatever you do, don't use those "stepped" valve adjustment feeler gauges. The "step" is usually .002" which is much too sloppy.
                      I found the stepped one was easier to work with though, if you have a steady hand, i dont see why not. as long as the surface is flat, and you can get the proper ammount of drag, you should be set. I found the angled ones were easier to work with then the regular flat ones.
