slipping clutch..
    slipping clutch..
    when you step on the clutch really fast and the rpm rise's alittle does that mean it is slipping or its normal...
    thats always happen to mine and im sporting a lightened flywheel.
      same here. I guess its momemtum (sp?)
      93 Accord LX Sedan (sold)
        You are letting the engine run without having to spin the transmission gears so the RPM's will go up until the ECU can adjust for it.
          If your foot is still on the gas the rpms go up do to less rotating mass on the motor.
          2008 3.5SE Altima
          1992 EX Coupe-FAIL
