Taillights question
    Taillights question
    Would the little box on the back of our taillights cause the to blink erratically when i step on the brakes? According to the honda parts department website its called a stop lamp failure sensor.
    <Need to fix so i can get my car inspected. I've checked almost everything and I'm running out of ideas.>
    1992 Honda Accord 4 door 5spd *Sold 5/9/09*
    Its your brake lights or turn lights?
    "The greatest loyalty in life is, above all, to thine own Self be true."
    Facebook
    MySpace
    My Ride
      Sorry wasn't specific when i wrote the first one. Its the turn signals that go crazy when i step on the brakes with the turn signal blinking. Also when i step on the brakes instead of lighting up the normal brake lights, it lights up the turn signals. (I've checked all the wiring and all that and everything is in the right place so idk what is going on)
        I suppose if the circuitry was screwed up, it would cause the turn signal lights to flicker. By the way, it sounds like you have the brake light bulb sockets fastened to the turn signal holders in the lens. Are you sure everything is hooked up correctly?
        "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
