Bolting the flywheel to the motor will likley cure most of "shakes at nearly all speeds"
My cb7 build. Sponsored by CrzyTuning!
This topic is closed.
Replaced all of the following:
-timing belt
-oil pan gasket
-valve cover gasket/tube seals
-lower spark plug tube seals
-cam seal
-rear main seal
-front main seal
-balance shaft seal
-thermostat gasket
-water pipe o-ring gaskets
-injector o-rings
-intake manifold gasket
-exhaust manifold gasket
-VSS
Still need:
-spark plugs
-plug wires
-distributor cap/rotor
-engine oil
-trans oil
-coolant
-a few coolant hoses
-H23 upper plenum/IM
Everything except the H23 plenum/tb should be done by this Friday in time for our get together, hopefully.Last edited by d112crzy; 03-10-2009, 10:22 PM.
Originally posted by Junior91 View Postlol nah guy not yet. THe car doesnt even run right now. needs a new starter and the tags are expired.
