prelude suspension
    prelude suspension
    Hey,does Anyone Knows If A 97-01 Prelude Suspension Fit On My Cb,i Mean Springs And Struts.
    If it helps, the struts/springs on the 92-96 prelude and 97-01 prelude, are interchangable.
      IIRC, the rear suspension is the same, but the front is not, or vis versa. Either way, all of the suspension will not fit.
        92-96 prelude and 97-01 Prelude base share the same suspension both front and rear, The 97-01 Type-SH has a different suspension in the front.
          He wants to know if it'll fit on a CB, not the interchangability between the generations of Preludes.
            I Guess If They Are Interchangable B2een Gen It Might Fit My Cb.92-96 Ludes Share Similaritys With The Cb,right.
              well if anyone comes up on a suspension of either generation it is useful information for them.
              I don't know of anyone who has tried fitting the suspension before.
                Well,i'll C If Is Not To Late(if The Lude Didn't Go To Auction)and Ask To Swap And Let U Guys Know.
                  Prelude suspensions do not fit on CB7s. 5th generation Accord suspensions will fit, but that's all.
                    i know this is kind of a old thread but the prelude front suspension will fit. i just got done swapping the front crossmember, radius arms,lower control arms, spindles and tie rod ends. it all fits. the inside mount for the lca on a accord is slightly smaller than the preludes so a little bending is needed, only about a 1/8 inch or less. the prelude lca is longer, wich is why i did not use the uca. a camber kit is necessary for proper alignment.it did make the track of the front wheels wider but not by much. have not driven it much (no time) so i cant tell a handling change. took some pics. enough to do a diy if anyone wants? got all the parts for free so it was worth it to me. btw all 96 lude parts were used. i think base 97-01 prelude spindles will work though, if u wanna do 5 lug!
                    some cars have wings cuz they look cool.
                    some cars have wings cuz they increase efficiency.
                    some cars have wings to keep them from taking flight.
                    f1 fan
