Oaay just received the Integra C pillar bar and i am coming up about 3-4 inches short. Whats the problem. Several people on here have made it work so what do i need to do??????????????????
C pillar bar install Question. HELP ASAP
Originally posted by 92jdm View Postwhat year integra did you order for
Originally posted by poolhall.junkie View PostBoth DA and DC2 Integra bars are the same length. The DA bar is actually shorter but I bought the DC2 bar which taps oout at 46.5 inches. I went and bought some washers and longer bolts. Cutting the plastic is the main bitch in all this. Hopefully that will work and it will not look to gaudy.
Well I finally got it together after about 25 washers on each side. Something has to be wrong for others to fit and mine come up so short. DA bar i think measures at 44 and the DC2 bar goes from 44 to 46.5. Makes no sense. Its in so o well I guess. Just to figure out a way to make the square that i cut around the bar look clean. Im think about some type of molding and some cloth like a boot or something to put in the hole to hide the washers and what not. Any suggestions??????
Originally posted by poolhall.junkie View PostWell I finally got it together after about 25 washers on each side. Something has to be wrong for others to fit and mine come up so short. DA bar i think measures at 44 and the DC2 bar goes from 44 to 46.5. Makes no sense. Its in so o well I guess. Just to figure out a way to make the square that i cut around the bar look clean. Im think about some type of molding and some cloth like a boot or something to put in the hole to hide the washers and what not. Any suggestions??????
Originally posted by AbsurdNY View PostYou could get some black vacuum hose and slit it down the center then put it on the edge.
