odometer and cruise cotrol don't work..
    The electrical parts work.. I click on the the cruise button and set the speed.. the light comes on but when I step off the gas I decelerate like I don't have CC on.
    Also my odometer stopped working.. How do I go about checking to make sure everything is hooked up correctly?
    I never liked cars before my cb7
    Sounds like your speed sensor quit. Is your check engine light on?
      nope.. my speedometer works and I have no check engine light coming on.
        speed sensor doesnt necessarily throw codes well atleast mine didnt when it shit on me
        Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
        CLICK THE PIC
          hmm so how would I go about checking my speed sensor to see if it's working properly?
          Also.. would my speed sensor cause my CC and odometer to stop working?
            yep.....its prob the speed sensor in ur tranny. mine did the same shit so i changed it and everything works fine now
            the rebuild!
            http://www.cb7tuner.com/vbb/showthre...50#post2073450
              You can check it to see if it has proper voltage. And if I remember correctly, to do that, you have to jack the car up, so the front tires are able to spin freely. Get a volt meter and hold the volt meter on the prongs on the speed sensor, have someone spin the tires and see what the voltage is. I don't remember the parameters off the top of my head, but, a Hayne's and Chilton manual will help you.
              Is your speedo correct?
                I believe so.. I mean I haven't tested it or anything.. but it seems to be functioning properly.
