how much could i mill from my head and still be safe? i was thinking like .020 and have the head p/p,h23 im port matched,bisi im gasket,header or bisi header(if i can bring myself to pay $900),a6 cam or maybe a stage 1 bisi cam.
head milling
why do you want to mill the head? if its not much and basically a cleanup job then should be fine but i wouldnt suggest trying to raise compression by milling head.
member ride thread
DIVULGE MOTORSPORTS
Just be aware that if you warp the head, it is then garbage. They can only be milled so much.
But if you can do it free at your uncle's shop, then it's not a bad idea. If you ruin the head, you can just get another one!
I can't accurately answer your question, though, so I'm not going to try and end up giving you wrong information. Someone here will know better.
If you're too cheap to build the bottom end, then you don't need to focus on upping the compression too much. Stock bottom end components aren't meant to handle much beyond the stock compression. That being said, I'm not sure on what's the weak point on F22ax blocks, but the stock rods aren't beasts by any means.
Originally posted by wed3k View Posti went .030 and it gave me half a point in compression. thats as far as id want to go especially if you are getting a higher lift cam.
My 5.7 LS1 Holden Ute
Originally posted by mondojackal View PostStock bottom end components aren't meant to handle much beyond the stock compression. That being said, I'm not sure on what's the weak point on F22ax blocks, but the stock rods aren't beasts by any means.
Ive found that the f22ax weakness is the piston ring lands crack. havent seen many issues with rods and definatly none with the block.
member ride thread
DIVULGE MOTORSPORTS
