Can someone give me a complete list on what to buy for this swap? i just pick up a rear end crash auto 95 accord EX for 200 bucks and well... this is will be my first swap project. Would everything just be interchangeable? I dont have to buy like a obd0 obd1 conversion? Sorry im more use to civics then accords.
F22B1 question
Nope, it'll pop right in. um, they have Vtec, so it might be a good idea to use the f22b1's computer also. Not sure if you'd have to wire vtec?
Check out this post man, it also has a few helpful links from people.
http://www.cb7tuner.com/vbb/showthre...t=f22b1+wiring98' Mustang 3V Swap
11' VW CC R36
My guess is a 90 Accord, by his name... Which model CB7 doesn't have an impact on how it's done. Of course, manual/auto could make a difference.
Be advised that the F22B1 is not really an upgrade. The motor has less potential than the F22A in your car right now. If I were in your position, I'd sell the motor and part out the rest of the car for money to dump into the F22A.
Originally posted by deevergote. View PostIt's more like I'm against the SOHC VTEC F series engines. They really suck... Someone talking about the SOHC VTEC "upgrade" is as bad as hearing "why don't you put a B18 in there?" to me!
Man you have never said it better.....I got a 5th gen with the F22B1....it sucks....I would rather upgrade my 5th gen to a F22A6....lol....and sell that SOHC VTEC to someone else!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
...Zex wet kit, 65 shot, dual purge, JDM H22...pure sex! .....I owned 8 CB7's in one year...top that JARHEAD...lol
...this thread has been graced by the new CB7 King
Originally posted by deevergote. View PostI can respect an F22B1 in a 5th gen, simply because that's what came in the car. Plus, I run CD5tuner.com, and I can't think bad about those guys!
It's not a motor worth swapping. If you need a replacement, or you already have it... make the best of it. But it's not an upgrade. At all.
Yeah, don't get me wrong... the F22B1 is an AMAZING motor for what it was designed to do... which is give good gas mileage and last forever... Maintain that thing, and you'll never swap an H22 in there!
It's just... not a performance motor. The VTEC system and emissions requirements caused the engineers to design the ports and valve angles in a way that doesn't allow for a significant increase in airflow.
The F22A, on the other hand, has the potential to flow MUCH better than a simple family sedan motor should! The port design is fantastic, and the valve angle is nearly ideal. The exhaust ports are the biggest restriction on the F22A head. Open those up, and major gains will be seen. Continue to properly port and polish the entire head, and do a good valve job... and it'll be significant. Add a nice cam, bump up compression, toss on the proper quality bolt-ons, and tune that sucker... and join the ranks of 250+whp F22As that are on the road
Originally posted by deevergote. View PostYeah, don't get me wrong... the F22B1 is an AMAZING motor for what it was designed to do... which is give good gas mileage and last forever... Maintain that thing, and you'll never swap an H22 in there!
