How do I drain the power steering fluid so i can pull the motor?
Draining Power Steering
http://www.cb7tuner.com/vbb/showthre...=steering+rack
That 1st pic isn't super clear, but you should get the point to drain the entire system. But you mentioned yanking the motor, you can swing the pump out of the way, leaving the system intact, plus the VSS hoses allow you to pull the VSS out of the tranny and swing it out of the way aswell. Or if the p/s pump is still in the way, you can ditch the pump and simply connect the end of the high pressure line to the feedline w/ the existing clamp, works great.
