Alternater Belt Squeeks
    Could also try some belt dressing or something to lube the belt so it wouldn't squeak. Still just tighten the thing and don't be lazy.
    "The Turtle"
    DD/Trail Rig/Mud Bug
      My wifes accord has the same problem. I'm on a second set of new belts and the squeel is still there.
      I tightened the belts several times and it stopped for a day or two. Tried belt dressing and silicone spray with the same result. Then i thought it was faulty belts so I got another set and same thing happend. I put a wrench on the alternator pulley and turned it. Looks like the belt is slipping on the crank pulley even though it's plenty tight.
      I'm about to go to the dealer and get some oem belts or look for another crank pulley unless somebody has a better idea.
        I did some research. Seems like this is a common problem with cheap aftermarket belts. I'm going to the dealer to get a oem belt.
