yo guys im being a n00b with the h22 swap questions but whats it take to get a obd2 h22 from a 97 lude to work in our obd1 cars. i tryed searching couldent find but i know its on here so if you guys can lead me to the right threads or and diy for the h22 swap....thanks
obd2 to obd1
Try www.nipponpower.com look in the electrical section they have them there. If you need help finding the 1 you need just e-mail them to find the 1 you need. Hope this helps.
LaterBought from: Jack_Lee, Hondaguy1212, cb7dazz, dannyd, frootloops, ncoutlaw, busak87, Losiracer2, KeeleDesign, 1993ACCORDMAN, gdout90accord, sikz6, Type_G
Sold to: 1993haccord, samrjr0044, blk91coupe
I have a 98 type s motor and and as N9netwoAccord, you may need the obd1 injectors and run another custom wiring. As for the ECU, you can run the p13 or the p28.
The obdII motors are not nice for tuning. Thats why a lot of people convert to obdI.
Here is the info you will need.
http://www.cb7tuner.com/vbb/showthread.php?t=126672
This is the link for the harness so you can run and obdI ecu
http://www.evasivemotorsports.com/Me...ode=OBDHARNESSLast edited by jimy; 02-22-2009, 06:04 PM.
Originally posted by jimy View PostForgot that you'll also have to run two vtec lines for it also. But that post should cover most of it.
jumper harnesses are to convert obd2 cars to obd1. You don't need all that.
Like its been mentioned before up there. run your harness, obd1 injectors, ecu and dizzy. you may need to extend a few wires and change plugs.
you will need to wire up the vtec pressure wire and vtec solenoid. also ground the vtec pressure switch. If you run an stock P13 ecu, you'll also need to wire up the Knock sensor.
And like said before. the link above should have all of this info. already posted for you.
-Zol
WTB: rightside jdm 1piece headlight or just glass.
