Getting 16-18 MPG
    I get 13 MPG. Be happy.
    90 Accord EX F22a1 Auto R.I.P.
    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
      Dam, i thought I had a heavy foot, and was getting bad mileage... 20mpg w/ac, 24 w/o ac for city/highway driving. I used to get 28city/32highway w/o ac. I know i'm about due to for a timing belt job, and i've been having to add plus to keep the pre-detonation caused from running rich. Also my plugs & distributer cap could use a cleaning, will see how much of an improvement those make, and the timing belt job here shortly.
        I dont have a heavy foot. I have an A1 1990. Nuff said. And im using 87 octane. Not your regular which is basically our premium
          I get 25 mpg on my auto wagon with a semi heavy foot with a little bit of city driving. I might can get 27 if I am easy on her on the highway!
            i have a 91 a1 and an auto, and i was using 87 before I started to hear a clankety clank clank sound when I "put my foot in it", i changed to premium and the sound it was making wasn't nearly as loud, and its duration was reduced 90%. (A mechanic of a acura/honda specialty shop down heres recommendation after taking a test drive so he could feel the slight shake/shudder my car gets when you "petal to the metal")
            My regular is 87, plus is 89, and premium is 92, and thats with 10% ethenol in the mix.
              sea foam is the cheap easy way to start out to get back the mpg i sell it at my work and i have had no one ever say anything bad about it... it works very well.
                Here's your first then:
                It fouls the shit out of your plugs. It turns them purple, and they dont ignite properly.
                If your going to run Seafoam, for gods sake, please use premium fuel as well. It burns hotter, so the seafoam will probably be ripped off the plugs. I hear ups and downs, i know on both my previous cars, i used one can in each. Both cars engines were toast after about a week.
                  It also depends on what way you use it, and how much you used.
