Open Door Switch
    Open Door Switch
    My drivers door open switch thing stopped working.
    like when i open the drivers door the light doesn't come on and the windows are always on.
    and it like killed my battery. how do i fix this
    unscrew it and clean it out. On the side of the door sill. Moves side to side. Wd-40 it. If that doesnt work then head for the jy.
      Where is it?
        Its the black switch that slides back and forth right by the door catch on the jamb. Its held on by 1 phillips screw.
        When you pull it out there will be one wire inside plugged onto it. (Ground Fault) so don't worry about a short circuit when you unplug it.
        I break my drivers door one all the time cause I slam my seat belt in it.
        What do you mean windows are always on? Are you refering to the windows rolling up after you shut the car off? Thats normal for about 5 mins then they quit.
        GOT F?
          That switch didn't like kill your battery. If it made the dome light stay on, yeah, but if the switch doesn't turn the light on, it's not drawing juice. You've got another problems somewhere.
          And your windows should roll up and down for ten minutes or until a door is opened, whichever comes first.
            I took that piece out. I like having the radio on with the door open with out the annoying beeping sound. I like being able to roll up my windows with my door open and the car off... Its really not too bad.
