Slight Vibration @ Stop Lights ?
    i replaced ALL my mounts at once and it wasn't until then that i noticed the vibration when coming to a stop. it will sometimes vibrate if i let off the brake and the car gets going enough to raise the RPMs to about 900-1k. i think it has partly to do with using stiffer aftermarket mounts. i'm just learning to deal with it.
      i have the same problem and im thinking of switching to innovative mounts(plan a 5 speed swap) and i just wanted to know if this is still a problem on 5-speeds or if its only on automatics
        well im here @ the shop and i turns out it was a connection that wasnt connected to the tourqe convertor or something of the sort .. the plug had a wire that wasnt connected..
        and as i told him to throw in the new NGKs i bought he showed me i had oil in the spark plugs ..so im getting that fixed as well... i hope to see improvment on the F22 =)
        thanks once again guys
        Check Out My Work In Progess . . . . .
          I have the same problem as do a few others i notice it seems to be a reoccurring thing with auto tranny's.
