Balnce shaft ?
    Balnce shaft ?
    has any one ever taken the balance shaft belt off and drove without it have read engine vibrates a lil more but u gain 3-5 whp. lmk if this is true.
    ive seen numerous people do it, however the gains i dont know about.
    id say if anything...you just take some strain off the motor which cant hurt it
    although, who knows the after effects if any.
    smoke tires, not drugs.
      ive done this to 3 of my cb7s. no extra vibration at all. and you can feel the extra gain you get from it too.
        any pics of this balance shaft?
          mmmmmmmmm the stock on on f's n h's, if u don't know what it is look it up.
            ttttttttttt
              is it just simply just not use the lil belt??
              cuz soon im a do a t-belt and all that cuz i have a cam seal leak, so when i buy the parts i wont need the smaller belt???
                engine vibrates
                what can cause it to vibrate in idle when the only motor mount i havent change is the one by the belts
                  Its recommended that you replace the seals as follows: Cam seal, Crank seal, Ballancer seal, Timing belt, Ballancer belt, and the water pump. Pump is obviously a bit harder, and i didnt do mine. I did do the rest however. Look at my thread "Ballancer shaft seal" for a picture.
                  90 Accord EX F22a1 Auto R.I.P.
                  2011 Mazda 3 Hatch 2.5L GS sport HELLO!
                    yeah I did it to my F22 when I had to do the headgasket on it, all I did was leave the belt off and nothing was harmed from what I noticed, although I only drove the engine for about 5K before I swapped to an H22, so for longevity purposes I wouldn't know. But the car just felt a bit rougher at lower RPMs, like I could feel the engine more through the pedal area, but nothing bad or anything. I hardly noticed it after a week.
