h23 hybrid turbo
    h23 hybrid turbo
    ok first i have a complete dsm 14b turbo kit etc,
    an f22a1 thats in my accord now and a h23 complete swap,
    question: ok wikipedia.com say that the h23 shares
    the same Fiber Reinforced Metal (FRM) cylinder wall liners
    with the H22a...true or false?
    i know that the f22 has iron sleeves, if the h23 doesnt
    have iron sleeves iam gona bore that f22 to 87mm or 86mm to accept
    h23 piston or f23 piston and throw the rest of the internals in there too.
    and would the f22 walls be to thin bored to 87mm or 86mm and put f23a1 pistons to lower compression some? would this be a decent set-up?
    fyi using a compression calculator h23 head + f22 block (bored to 86mm) + f23 86mm pistons = 8.6:1 compression/2.21 liters.
    Why do you want to mess with internals, you have two great engines for boost application h23 non vtec has FRM walls like H22 but it also has lower compression than that H22 which is good for boost, tune is the key on that motor(look at drummersteve7 build, he is boosting one as we speak)
    What you need is better turbo, 14b is only good for 10-12psi and 200-250hp.
    Bigger turbo will give you more room to play, as it won't torture your motor with heat.
      9:1 compression stock is fine on the h23a1.
        booth are good engines stock ur going to waste a lot of money and not get the best of numbers. imo sell h23 and get a t3 t4 turbo kit.
          well which one would be better to boost?
          and would a 16g turbo run cooler?
          i have read that a h23 compression is actually 9.8:1
            Resleeving is a must to even think about turboing.
            www.PreludePower.com
            BB SQUAD MEMBER #28 V.2
              H23 would be better because it's DOHC, tuning for turbo with SOHC is not that great even if you have turbo cam, which is must to avoid overlap.
              16g is better than 14b but still not that great of a turbo, if you can get Big 16g evo III than we are talking about good turbos, you know what I'll take pic for you of all three compressor wheels so you can see yourself.
              16g is just slightly bigger that 14b, it has bigger inducer and about same size exducer which I belive will make heat like 14b's but feed more air than when need it. Then evo III wheel has bigger inducer bigger exducer like 18g and 20g that spool slower but does not make as much heat and flow really good with our motor. I wish my camera didn't die so I could take beck to beck pic.
              14b............................................... ......16g......................................... ....................evo III 16g
                The FRM sleeves are NOT weak. I wish people would stop assuming this. Boring the F22A would result in MUCH weaker sleeves than the H23's stock FRM sleeves.
                Just boost the stock H23 if you don't want to resleeve and run forged internals.
                BUT, get a bigger turbo. You're going to blowtorch an H23 with a 14b. That turbo is way too small. The "Big" 16G from an Evo 3 is better, but still not a great idea.
                  dam, and 2 think i was gonna boost a h23 wit a 14b
                    yah
                    the only reason I am running a Big 16G setup is due to the fact that it has been ported and I really want boost for this summer.
                    my next h23 build is going to be a bigger turbo. Holset HX35.
                    IMO just boost that stock H23. It is a sweet motor.
                    In the following link there are a lot of good questions and information regarding the H23 boosted.
                    Link to my Boost Build
                    Regardless Boosting the F22 still should yield more power than a H22 swap.
                    It is a great engine. This will be my first time playing with the H23.
                    Have you decided which route to go?
                    MadLab Racing
                    Southern Maryland
                      iam gona boost the h23 but with wat turbo iam deciding?
                      14b = no
                      16g big = maybe
                      what about a holset hx35 turbo?
                        Wouldnt running forged pistons in FRM cylinder walls ask for trouble though?
                          Yes, they would. But I believe he's talking about boosting a stock bottom end.
                          Also, Mahle makes pistons that are compatible with the FRM sleeves. I believe JUN and Cosworth do as well.
                            which iws better? the h22 or the h23
                              To the op..u could get a hy35 (baby brother of hx35) and get a BEP housing(bullseye performance)..which allows u 2 retain the dsm manifold..and 5 bolt dsm downpipe..thus..making the switch to the bigger turbo easier..if ur not starting there..the hy35 is good for around 300-350whp more than what ur gonna need on stock internals..and still will spool pretty nice in the bep (55ar) housing.
                              Evo3 16g should be the only option 2 consider out of the small dsm turbos..anything below is a waste of time for power reach and durability of the engine
                              Praise The Lowered...
