Got a problem
    Got a problem
    Hi names Jay. Well here it goes. Its a 92 LX Sedan all stock auto trans.
    Ok when i'm driving 30-40 and 56-60 and i'm on the gas feels like the car is
    slightly jurking along. Tried to pull trouble codes but none. No CEL. I was told it might be a grounding problem. Cause I replaced the whole cooling system.
    except the water pump. Said might be the grounding wire under the termostat
    housing not grounding good. Any help would be appreciated. Oh and thanks in advance. And yes I did do a search but nothing.
    lets start with basics and history.
    have you done a tune up and whats the background on the vehicle?like maintainence wise...
      X2
      Need more details - When did the problem occur, What recent work have you done to the car, etc.
      When does it jerk? Low rpm, High rpm, cruising?
      My 5.7 LS1 Holden Ute
        If you suspect a grounding issue, check and clean all grounds.
          Well just got the car about 2weeks ago. I did the basic tune up cap,rotor,plugs,wires. Did trans fluid change. & yes hondafluid. Also changed the radiator,hoses,thermostat. But I did notice it felt a little sluggish. Just didn't think anything. But the trans was over full when I got it. Did the fluid change and its fine. I got it with 76000miles. Has 78000 now. Whatever help would be very appreciated. Other than that don't know much history about it. As for the jurking I could be cruising
          around 50-60mph then when I step on the gas its starts to kinda jurk slightly. RPM would be 2000-2700. I would notice 30 -40mph. Thanks again.
