Control Arms
    Control Arms
    So i am going the buy the camber and caster (lower and fixed control arms) but i also have this problem that when im driving at a high mph like 90 or 100 i can feel the front wheels kinda shaky...
    I already got my alignment and apparently that wasnt it
    will the control arms fix this problem and keep everything stabalized so that it can run smoothly?
    For the front end feeling "loose", An alignment will help but will not solve all the problems. First step would be to start replacing ball joints and bushings if they are worn. Shocks and springs are next.
      Originally posted by bruno8747 View Post
      If you do not care to offer help then don't post that you will not help the individual.
      As far as the front end feeling "loose", An alignment will help but will not solve all the problems. First step would be to start replacing ball joints and bushings if they are worn. Shocks and springs are next.
      I got my lower balls joints changed as well, and my tie rods, i believe it might even b the bushings then cause i dont no if they were changed
        One more thing I forgot. Get your wheels balanced properly. That normally accounts for high speed vibrations. Sometimes you have a slight bend in the rim and wont know it.
          got them balanced 2 :-/
            But, for shits and giggles, it could be:
            Bad bearing
            Bad axle
            Loose studs
            May have a flat spot on one of your tires
            maybe bent wheel(s)
            Bad ball joints
            Bad rotors
            Worn CV joint
            Uneven tire pressure
            Bad Tie rods
            and the list goes on and on.
            If you take it to a shop, they can check all the components, and suggest what could be wrong based on the inspection.
              Originally posted by Joshs92ex
              I do care for the well being of member's and other innocent driver's that will be in harms way. What's a situation in which one would need to go 90+mph?
              And DrSzSoLDIeR, feel free to say something rude to me. I'll be sure to pass it on to your family to put it as your epitaph.
              .........thanks
                it depends on what kind ofbalancing machine the shop has but at school we can measure rim runout and one of my rims are kinda bad and no matter how well i balance it...it will still shake a bit.
                tried rotating the wheels to the back and see if that will help?
                  Cleaned your thread up for you DrSzSoLDIeR
                  Have you gone through this yet - http://www.cb7tuner.com/vbb/showthread.php?t=119467
                  Main issues I could see - Wheel balance (even 1 gram out can be very apparent at 100mph) Wheel bearings, axles, suspension joints.
                  My 5.7 LS1 Holden Ute
