fans wont turn on
    fans wont turn on
    hey i recently had a probelm with or not having a bad head gasket.....
    it throws white smoke then it just calms down its not norma smoke its that thick white one....
    then i replaced my radiator cause i needed it too also...
    soo i did that i hooked up all my fnas again
    and now they wont turn on anymore.....wcause with the old radiator it use to turn on like 5 mins after letting it sit after normal temp..
    is it because i installed a new radiator that they dont go on????
    but when i drive around the block 2 times i see smoke coming out of the radiator ......
    my temp insid ethe car is normal..
    can it be the thermonstat not opening????
    can we take of the thermastat>????
    IT MAY BE AUTO BUT IT SURE RUNS FAST FOR A F22A6
    My engine fan also fuked up last summer, the problem was the FAN TIMER RELAY,,, maybie it isnt your problem but it could be a source of it...
      well it was working also....
      they turn on when i use the ac....
      maybe the radiator is throwing smoke cause the fans wont turn on to cool it donw
      where is that located?
        under the dash/driver side..... and the smoke is maybie an other thing...
          well is it a fuse or what???
          cause i see the 6 lil blocks...
          but mine dont have the cover...for it soo i cant tell whats what....
          only for the fuses under the dash...............
          the smoke comes from the radiator....
          i guess the fans dont turn on or something......and dont cool it off
            It looks like a thermostat problem... you should call a honda garage... And the lil box is black and its difficult to find its almost under the speedometer.. its far under the dash and its black.... you could search in the forum... cause i didnt took pics but i know somebody did it...
