g23 ?
    g23 ?
    Has anyone dun a g23 ?
    I would like to know I u like it and how hard it was to get the parts
    How much did it cost u ?
    Thanks
    what is that engine out of???
    Heart and Brain Transplant fail I had to pull the plug
    My new best FRIEND!!!
      Welcome to the site. The g23 is a hybrid f22 bottom, h23 head, it's also not the best way to go. If you use the search function in the upper right and look for g23, you'll come up with this list of threads about everything you want to know.
      http://www.cb7tuner.com/vbb/search.php?searchid=3663014
        Is an f23 , h22 and k20 all put 2gether
          http://www.cb7tuner.com/vbb/showthread.php?t=124641
          http://www.cb7tuner.com/vbb/showthread.php?t=122282
            But, it's so hard!
              Thanks 4 the links
                its worthless. you mix those parts and you get a motor with lower compression that doesnt rev high enough for the head to do what its supposed to do.
                a g23 is like a retard with a masters degree.
                  Ahhahaah that's funny
                    I hope I get more input on this
                      my g23 actualyl ran like a bat out of hell but i also had a lot more done than your normal f22.
                        just like a ls vtec put them together stock and u spin bearings reving to the head's earlier stock redline.
                        do u have a build sheet on that?
                          not really a legitimate build sheet.
                          it was just a low mileage f22a6 (20k miles)
                          H23 head
                          -milled .020
                          -valve job
                          -f22a6lower intake manifold
                          -h23 upper with TB
                          DC sports header
                          custom 3" intake
                          p06 ecu with f22b dohc basemap
                          ground wires
                          removed power steering belt
                          a/c delete
                          test pipe
                          apexi WS1
                            Thanks
                            my friend/mechanic built one a while back, it was a beast. too bad he used the wrong piston pins and then slipped out and threw a rod. hes on his second build with a with better mods and h2b kit. its coming along nicely.
                              Pistons : stock 87mm used h22a pistons w/new rings $120
                              Rods: stock rods shot peened
                              Block: f22a1 $150
                              Crank: stock crank blueprint and balanced
                              Camshaft: stock for now
                              Valves: stock
                              Springs: kms
                              Retainers: kms
                              Head: $200 for a h22 head and get a port and polish on it
                              qsd h2b kit $750
                              kaizenspeed balance delete kit $150
                              So buying all the parts with machine work is going to cost me about 2.2k
                              comp. should be around 11.1 with stock cams I should be around 220 whp on a good tune. And this is my all motor future set up.
